이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Close the laptop lid and flip the laptop over.
Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
Push the release button to the right.
Hold the release button to the right and lift the battery out of its housing.
Open the laptop so the keyboard is facing you.
Using your fingers, remove the thin plastic cover above the keyboard.
Remove the two 4.8 mm screws from underneath the plastic cover piece using a Phillips #00 screwdriver.
Starting at the top, gently raise the keyboard enough to remove it from the socket.
Locate the data cable that is connected to the motherboard.
Pull the white ZIF connector towards the screen to remove it.
Pull the black ribbon cable away from the screen.
With the black ribbon cable now disconnected, remove the keyboard from its housing.
다른 3명이 해당 안내서를 완성하였습니다.
