소개
Welcome to the Toshiba Satellite L305-S5875 LCD Screen Replacement guide page. The ultimate goal of this page is to show you how to replace the 15.4" LCD screen on your Toshiba Satellite laptop. This guide will go step by step in explaining how to work your way to the screen, and then how to replace the screen once you're there. This guide uses both visual and written instructions to help you replace your old damaged screen with a brand new one.
필요한 것
Close the laptop lid and flip the laptop over.
Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
Use the plastic opening tool to separate the front panel of the laptop from the back panel, pulling the front panel off the laptop.
Gently pull the back panel approximately 1 inch away from the screen.
Unscrew and remove the 4 screws on the left and right side of the screen; 8 screws in total.
Now that you have removed the damaged screen, it is time to replace it with the new screen.
Follow these steps in reverse order to reassemble your laptop.
You have completed the LCD screen replacement guide for the Satellite L305-S5875. Great job!
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
My problem is a little different; mine broke near the hinge on the left side. So I need to remove the whole thing from the hinge up. Help?
DBethke1959@GMail.com
