소개
Installing additional RAM modules will increase the performance of your laptop, and is relatively easy to do.
  1. Close the laptop lid and flip the laptop over.
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Push the release button to the right. Hold the release button to the right and lift the battery out of its housing. Hold the release button to the right and lift the battery out of its housing.
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Locate the RAM Module compartment on the bottom side of the laptop. Carefully remove the 4.6mm 0 Phillips head screw and put it in a safe place. Locate the notch on the screw side of the lid and lift to remove it.
    • Locate the RAM Module compartment on the bottom side of the laptop.
    • Carefully remove the 4.6mm 0 Phillips head screw and put it in a safe place.
    • Locate the notch on the screw side of the lid and lift to remove it.
  5. Push the metal tabs on the sides of the RAM outward and the RAM will pop up. Gently pull the RAM out. Replace the RAM by sliding the new one into the angled socket similarly to how you removed the old RAM.
    • Push the metal tabs on the sides of the RAM outward and the RAM will pop up.
    • Gently pull the RAM out.
    • Replace the RAM by sliding the new one into the angled socket similarly to how you removed the old RAM.
    • Gently apply pressure until the metal tabs on the sides click into place.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Elliot Fiske
회원 가입일: 2013년 01월 30일
36 평판
안내서 1개 작성함
Cal Poly, Team 20-5, Maness Winter 2013 Cal Poly, Team 20-5, Maness Winter 2013 회원
CPSU-MANESS-W13S20G5
4 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 23
전체 시간: 6,088
