소개
Use this guide to remove housing on the base of your Toshiba Satellite L305-S5946. Removing the housing gives you access to the motherboard, processor, power jack, fan, and LCD screen.
필요한 것
Loosen the two captive screws on the bottom left corner of the hard drive using a Phillips #1 screwdriver until you hear a click.
For the following steps, use a Phillips #1 screwdriver.
Remove the twelve 6-mm screws that border the bottom of the laptop.
Remove the 6-mm screw located in the lower middle of the device.
Remove the three 3-mm screws located in the battery bay.
Remove the one 4-mm screw located near the RAM.
다른 한 분이 해당 안내서를 완성하였습니다.
