주요 콘텐츠로 건너뛰기
Toshiba Satellite L305-S5946 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite L305-S5946 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Place the laptop upside-down with the display hinges facing away from you.
  2. Toshiba Satellite L305-S5946 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Slide the latch for the left battery bay to the left.
  3. Toshiba Satellite L305-S5946 Hard Drive Replacement: 3 단계, 이미지 1/3 Toshiba Satellite L305-S5946 Hard Drive Replacement: 3 단계, 이미지 2/3 Toshiba Satellite L305-S5946 Hard Drive Replacement: 3 단계, 이미지 3/3
    • Slide the latch for the right battery bay to the right and hold.
    • Continue to hold the latch while using a plastic opening tool to lift and remove the battery bay cover.
    • Remove the battery.
  4. Toshiba Satellite L305-S5946 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/1
    • Loosen the two captive screws on the bottom left corner of the hard drive using a Phillips #1 screwdriver until you hear a click.
  5. Toshiba Satellite L305-S5946 Hard Drive Replacement: 5 단계, 이미지 1/2 Toshiba Satellite L305-S5946 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Lift the hard drive cover using a non-marring iFixit opening tool.
    • This will expose the hard drive.
  6. Toshiba Satellite L305-S5946 Hard Drive Replacement: 6 단계, 이미지 1/3 Toshiba Satellite L305-S5946 Hard Drive Replacement: 6 단계, 이미지 2/3 Toshiba Satellite L305-S5946 Hard Drive Replacement: 6 단계, 이미지 3/3
    • Slide the hard drive to the left using your fingers.
    • Remove the hard drive by inserting an iFixit opening tool under the right side of the hard drive and carefully lifting it out.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Alec
회원 가입일: 04/18/13
346 평판
안내서 1개 작성함
Cal Poly, Team 3-49, Amido Spring 2013 Cal Poly, Team 3-49, Amido Spring 2013 회원
CPSU-AMIDO-S13S3G49
4 회원들
안내서 19개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 2,092
