주요 콘텐츠로 건너뛰기
Toshiba Satellite L305-S5946 Power Jack Replacement
필요한 것
  1. Toshiba Satellite L305-S5946 Power Jack Replacement, Battery: 1 단계, 이미지 1/1
    • Place the laptop upside-down with the display hinges facing away from you.
  2. Toshiba Satellite L305-S5946 Power Jack Replacement: 2 단계, 이미지 1/1
    • Slide the latch for the left battery bay to the left.
  3. Toshiba Satellite L305-S5946 Power Jack Replacement: 3 단계, 이미지 1/3 Toshiba Satellite L305-S5946 Power Jack Replacement: 3 단계, 이미지 2/3 Toshiba Satellite L305-S5946 Power Jack Replacement: 3 단계, 이미지 3/3
    • Slide the latch for the right battery bay to the right and hold.
    • Continue to hold the latch while using a plastic opening tool to lift and remove the battery bay cover.
    • Remove the battery.
  4. Toshiba Satellite L305-S5946 Power Jack Replacement, Hard Drive: 4 단계, 이미지 1/1
    • Loosen the two captive screws on the bottom left corner of the hard drive using a Phillips #1 screwdriver until you hear a click.
  5. Toshiba Satellite L305-S5946 Power Jack Replacement: 5 단계, 이미지 1/2 Toshiba Satellite L305-S5946 Power Jack Replacement: 5 단계, 이미지 2/2
    • Lift the hard drive cover using a non-marring iFixit opening tool.
    • This will expose the hard drive.
  6. Toshiba Satellite L305-S5946 Power Jack Replacement: 6 단계, 이미지 1/3 Toshiba Satellite L305-S5946 Power Jack Replacement: 6 단계, 이미지 2/3 Toshiba Satellite L305-S5946 Power Jack Replacement: 6 단계, 이미지 3/3
    • Slide the hard drive to the left using your fingers.
    • Remove the hard drive by inserting an iFixit opening tool under the right side of the hard drive and carefully lifting it out.
  7. Toshiba Satellite L305-S5946 Power Jack Replacement, RAM: 7 단계, 이미지 1/1
    • Using a Phillips #1 screwdriver, turn the screw on the RAM cover until you hear a click.
    • This is a captive panel screw and remains with the cover.
  8. Toshiba Satellite L305-S5946 Power Jack Replacement: 8 단계, 이미지 1/2 Toshiba Satellite L305-S5946 Power Jack Replacement: 8 단계, 이미지 2/2
    • Remove the RAM cover by inserting the plastic opening tool into the indent and lifting.
  9. Toshiba Satellite L305-S5946 Power Jack Replacement: 9 단계, 이미지 1/2 Toshiba Satellite L305-S5946 Power Jack Replacement: 9 단계, 이미지 2/2
    • Push the white and silver retaining clips away from each side of the RAM card using your fingernails.
    • The RAM card should pop up at an angle.
  10. Toshiba Satellite L305-S5946 Power Jack Replacement: 10 단계, 이미지 1/2 Toshiba Satellite L305-S5946 Power Jack Replacement: 10 단계, 이미지 2/2
    • Pull the RAM card away from the computer.
    • Repeat Steps 6 and 7 to remove the other RAM card that may be installed.
  11. Toshiba Satellite L305-S5946 Power Jack Replacement, Keyboard: 11 단계, 이미지 1/1
    • Place the laptop right-side-up so the screen faces you.
  12. Toshiba Satellite L305-S5946 Power Jack Replacement: 12 단계, 이미지 1/3 Toshiba Satellite L305-S5946 Power Jack Replacement: 12 단계, 이미지 2/3 Toshiba Satellite L305-S5946 Power Jack Replacement: 12 단계, 이미지 3/3
    • Remove the strip of plastic at the right furthermost edge of the keyboard using a plastic opening tool.
    • Insert the plastic opening tool at either end of the strip.
    • Lift upwards and proceed to the other end while repeating this lifting process every one to two inches.
  13. Toshiba Satellite L305-S5946 Power Jack Replacement: 13 단계, 이미지 1/1
    • CAUTION: do not allow hardware or debris into the CPU fan and duct.
    • Remove the two 3-mm screws at the top edge of the keyboard using a Phillips #00 screwdriver.
    • These are not captive panel screws and, once loosened, will be free to move about the assembly.
  14. Toshiba Satellite L305-S5946 Power Jack Replacement: 14 단계, 이미지 1/2 Toshiba Satellite L305-S5946 Power Jack Replacement: 14 단계, 이미지 2/2
    • Pry the top of the keyboard loose from its casing using a plastic opening tool.
  15. Toshiba Satellite L305-S5946 Power Jack Replacement: 15 단계, 이미지 1/1
    • Gently grasp the top of the keyboard and pull it up and toward the screen.
    • CAUTION: Pulling too hard could damage the black ribbon cable under the keyboard.
  16. Toshiba Satellite L305-S5946 Power Jack Replacement: 16 단계, 이미지 1/3 Toshiba Satellite L305-S5946 Power Jack Replacement: 16 단계, 이미지 2/3 Toshiba Satellite L305-S5946 Power Jack Replacement: 16 단계, 이미지 3/3
    • Gently push the two tabs locking the black ribbon cable.
    • To remove the black ribbon cable from the motherboard, slide the keyboard toward the screen.
    • You may now safely separate the keyboard from the laptop.
  17. Toshiba Satellite L305-S5946 Power Jack Replacement, Base Housing: 17 단계, 이미지 1/1
  18. Toshiba Satellite L305-S5946 Power Jack Replacement: 18 단계, 이미지 1/1
    • For the following steps, use a Phillips #1 screwdriver.
    • Remove the twelve 6-mm screws that border the bottom of the laptop.
    • Remove the 6-mm screw located in the lower middle of the device.
    • Remove the three 3-mm screws located in the battery bay.
    • Remove the one 4-mm screw located near the RAM.
  19. Toshiba Satellite L305-S5946 Power Jack Replacement: 19 단계, 이미지 1/1
  20. Toshiba Satellite L305-S5946 Power Jack Replacement: 20 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to remove the five 6-mm screws in the keyboard slot.
  21. Toshiba Satellite L305-S5946 Power Jack Replacement: 21 단계, 이미지 1/3 Toshiba Satellite L305-S5946 Power Jack Replacement: 21 단계, 이미지 2/3 Toshiba Satellite L305-S5946 Power Jack Replacement: 21 단계, 이미지 3/3
    • Lock the white ribbon cable into place by gently pulling on the two black tabs.
    • Remove the white ribbon cable by pulling it towards you.
    • Remove the connector that has the blue, red, black, and white wires using tweezers.
  22. Toshiba Satellite L305-S5946 Power Jack Replacement: 22 단계, 이미지 1/3 Toshiba Satellite L305-S5946 Power Jack Replacement: 22 단계, 이미지 2/3 Toshiba Satellite L305-S5946 Power Jack Replacement: 22 단계, 이미지 3/3
    • Separate the laptop upper casing from the lower casing by using an opening tool around the sides of the case to pry it apart.
  23. Toshiba Satellite L305-S5946 Power Jack Replacement, Power Jack: 23 단계, 이미지 1/1
    • Flip over your laptop so that it is right-side up.
    • Open your laptop so that the screen faces you.
  24. Toshiba Satellite L305-S5946 Power Jack Replacement: 24 단계, 이미지 1/2 Toshiba Satellite L305-S5946 Power Jack Replacement: 24 단계, 이미지 2/2
    • Using your fingers, gently slide the DVD drive out through the opening on the right side.
  25. Toshiba Satellite L305-S5946 Power Jack Replacement: 25 단계, 이미지 1/3 Toshiba Satellite L305-S5946 Power Jack Replacement: 25 단계, 이미지 2/3 Toshiba Satellite L305-S5946 Power Jack Replacement: 25 단계, 이미지 3/3
    • Using your fingers, gently slide the heading with two black wires and two red wires out of its receptacle. Gently slide the power jack up.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Michael Erberich
회원 가입일: 04/17/13
130 평판
안내서 9개 작성하였습니다
Cal Poly, Team 3-49, Amido Spring 2013 Cal Poly, Team 3-49, Amido Spring 2013 회원
CPSU-AMIDO-S13S3G49
4 회원들
안내서 19개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 10
전체 시간: 7,799
