주요 콘텐츠로 건너뛰기
Toshiba Satellite L305-S5946 RAM Replacement
필요한 것
  1. Toshiba Satellite L305-S5946 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Place the laptop upside-down with the display hinges facing away from you.
  2. Toshiba Satellite L305-S5946 RAM Replacement: 2 단계, 이미지 1/1
    • Slide the latch for the left battery bay to the left.
  3. Toshiba Satellite L305-S5946 RAM Replacement: 3 단계, 이미지 1/3 Toshiba Satellite L305-S5946 RAM Replacement: 3 단계, 이미지 2/3 Toshiba Satellite L305-S5946 RAM Replacement: 3 단계, 이미지 3/3
    • Slide the latch for the right battery bay to the right and hold.
    • Continue to hold the latch while using a plastic opening tool to lift and remove the battery bay cover.
    • Remove the battery.
  4. Toshiba Satellite L305-S5946 RAM Replacement, RAM: 4 단계, 이미지 1/1
    • Using a Phillips #1 screwdriver, turn the screw on the RAM cover until you hear a click.
    • This is a captive panel screw and remains with the cover.
  5. Toshiba Satellite L305-S5946 RAM Replacement: 5 단계, 이미지 1/2 Toshiba Satellite L305-S5946 RAM Replacement: 5 단계, 이미지 2/2
    • Remove the RAM cover by inserting the plastic opening tool into the indent and lifting.
  6. Toshiba Satellite L305-S5946 RAM Replacement: 6 단계, 이미지 1/2 Toshiba Satellite L305-S5946 RAM Replacement: 6 단계, 이미지 2/2
    • Push the white and silver retaining clips away from each side of the RAM card using your fingernails.
    • The RAM card should pop up at an angle.
  7. Toshiba Satellite L305-S5946 RAM Replacement: 7 단계, 이미지 1/2 Toshiba Satellite L305-S5946 RAM Replacement: 7 단계, 이미지 2/2
    • Pull the RAM card away from the computer.
    • Repeat Steps 6 and 7 to remove the other RAM card that may be installed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Michael Erberich
회원 가입일: 04/17/13
130 평판
안내서 9개 작성하였습니다
Cal Poly, Team 3-49, Amido Spring 2013 Cal Poly, Team 3-49, Amido Spring 2013 회원
CPSU-AMIDO-S13S3G49
4 회원들
안내서 19개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 822
