주요 콘텐츠로 건너뛰기
Toshiba Satellite L305-S5955 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite L305-S5955 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5955 Hard Drive Replacement: 2 단계, 이미지 1/3 Toshiba Satellite L305-S5955 Hard Drive Replacement: 2 단계, 이미지 2/3 Toshiba Satellite L305-S5955 Hard Drive Replacement: 2 단계, 이미지 3/3
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5955 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/1
    • Locate the hard drive on the laptop, above the part number and serial number sticker
  4. Toshiba Satellite L305-S5955 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Remove the two screws marked "4" from the hard drive cover
  5. Toshiba Satellite L305-S5955 Hard Drive Replacement: 5 단계, 이미지 1/1
    • Pry up the cover of the hard drive compartment.
  6. Toshiba Satellite L305-S5955 Hard Drive Replacement: 6 단계, 이미지 1/2 Toshiba Satellite L305-S5955 Hard Drive Replacement: 6 단계, 이미지 2/2
    • Slide hard drive out by pulling gently on the felt handle
  7. Toshiba Satellite L305-S5955 Hard Drive Replacement: 7 단계, 이미지 1/1
    • Remove four outer black screws on the corners of the hard drive case
  8. Toshiba Satellite L305-S5955 Hard Drive Replacement: 8 단계, 이미지 1/1
    • Remove hard drive from the casing by gently sliding the drive out of the case.
  9. Toshiba Satellite L305-S5955 Hard Drive Replacement: 9 단계, 이미지 1/1
    • Complete these steps in reverse order to insert hard drive back into laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Eric
회원 가입일: 09/30/14
55 평판
안내서 1개 작성함
Ohio State, Team 1-2, Buehl Fall 2014 Ohio State, Team 1-2, Buehl Fall 2014 회원
OSU-BUEHL-F14S1G2
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 942
