주요 콘텐츠로 건너뛰기
Toshiba Satellite L305-S5955 Keyboard Replacement
필요한 것
  1. Toshiba Satellite L305-S5955 Keyboard Replacement, Lock Tabs: 1 단계, 이미지 1/1
    • Slide the lock tabs outward. The right tab will lock into place, but the left tab must be held in place.
  2. Toshiba Satellite L305-S5955 Keyboard Replacement: 2 단계, 이미지 1/1
    • When you hear a click, lift up and pull out the battery.
  3. Toshiba Satellite L305-S5955 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/1
    • Use a plastic opening tool to lift out keyboard lining portion located at the top of the keyboard.
  4. Toshiba Satellite L305-S5955 Keyboard Replacement: 4 단계, 이미지 1/2 Toshiba Satellite L305-S5955 Keyboard Replacement: 4 단계, 이미지 2/2
    • Remove the 3.6 mm Phillips head PH000 screws securing the keyboard.
  5. Toshiba Satellite L305-S5955 Keyboard Replacement: 5 단계, 이미지 1/1
    • Use plastic opening tool to pry out the keyboard, starting by the 'delete' key in the top right corner.
  6. Toshiba Satellite L305-S5955 Keyboard Replacement: 6 단계, 이미지 1/2 Toshiba Satellite L305-S5955 Keyboard Replacement: 6 단계, 이미지 2/2
    • Lift the keyboard up and locate the ribbon.
    • Gently pull the ribbon out of its compartment to release it from the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Chris
회원 가입일: 09/30/14
1 평판
안내서 1개 작성함
Ohio State, Team 1-2, Buehl Fall 2014 Ohio State, Team 1-2, Buehl Fall 2014 회원
OSU-BUEHL-F14S1G2
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 6
전체 시간: 915
