주요 콘텐츠로 건너뛰기
Toshiba Satellite L305-S5955 RAM Replacement
필요한 것
  1. Toshiba Satellite L305-S5955 RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Make sure before proceeding to power down, remove the charger, and close your laptop, to avoid damaging your device or harming yourself.
    • Flip laptop over and locate the RAM cover in the middle of the laptop.
  2. Toshiba Satellite L305-S5955 RAM Replacement: 2 단계, 이미지 1/2 Toshiba Satellite L305-S5955 RAM Replacement: 2 단계, 이미지 2/2
    • Unscrew the screw marked "4"with PH1 screwdriver.
    • Remove cover by lifting up and pulling it out.
  3. Toshiba Satellite L305-S5955 RAM Replacement: 3 단계, 이미지 1/2 Toshiba Satellite L305-S5955 RAM Replacement: 3 단계, 이미지 2/2
    • Push latches outwards away from the RAM chip until it pops up.
    • Fingers may be pinched by the latches.
    • Pull RAM chip out.
  4. Toshiba Satellite L305-S5955 RAM Replacement: 4 단계, 이미지 1/2 Toshiba Satellite L305-S5955 RAM Replacement: 4 단계, 이미지 2/2
    • Repeat Step 3 for the bottom RAM chip.
결론
Samuel Baker
회원 가입일: 01/30/17
307 평판
안내서 3개 작성하였습니다
IUPUI, Team 1-2, Baechle Spring 2017 IUPUI, Team 1-2, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S1G2
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 273
