주요 콘텐츠로 건너뛰기
Toshiba Satellite L305D-S5895 Keyboard Replacement
필요한 것
  1. Toshiba Satellite L305D-S5895 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Locate at the top of the key board a long thin plastic cover that extends from above the Del key to the top of the Esc button.
  2. Toshiba Satellite L305D-S5895 Keyboard Replacement: 2 단계, 이미지 1/2 Toshiba Satellite L305D-S5895 Keyboard Replacement: 2 단계, 이미지 2/2
    • Pry up this plastic cover using the Spudger, and carefully remove the plastic cover from the laptop.
  3. Toshiba Satellite L305D-S5895 Keyboard Replacement: 3 단계, 이미지 1/2 Toshiba Satellite L305D-S5895 Keyboard Replacement: 3 단계, 이미지 2/2
    • After putting the plastic cover to the side, locate the two screws holding the keyboard to the laptop.
    • Remove the screws using the Phillips #0 screwdriver, and place the screws on the magnetic board.
  4. Toshiba Satellite L305D-S5895 Keyboard Replacement: 4 단계, 이미지 1/1
    • Lift the keyboard up in order to remove the cable.
  5. Toshiba Satellite L305D-S5895 Keyboard Replacement: 5 단계, 이미지 1/3 Toshiba Satellite L305D-S5895 Keyboard Replacement: 5 단계, 이미지 2/3 Toshiba Satellite L305D-S5895 Keyboard Replacement: 5 단계, 이미지 3/3
    • Notice the two white tabs on the compartment holding the cable.
    • Carefully unplug the keyboard from the motherboard by pulling the two white tabs away from the compartment holding the wire.
결론
Tyler GLick
회원 가입일: 10/21/16
101 평판
안내서 1개 작성함
UMass Dartmouth, Team 2-8, Isaacson Fall 2016 UMass Dartmouth, Team 2-8, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S2G8
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 319
