주요 콘텐츠로 건너뛰기
Toshiba Satellite L305D-S5895 RAM Replacement
필요한 것
  1. Toshiba Satellite L305D-S5895 RAM Replacement, RAM: 1 단계, 이미지 1/2 Toshiba Satellite L305D-S5895 RAM Replacement, RAM: 1 단계, 이미지 2/2
    • You will use your P0 screwdriver attachment to undo this screw.
    • Undo the screw using the screwdriver.
  2. Toshiba Satellite L305D-S5895 RAM Replacement: 2 단계, 이미지 1/1
    • Use your finder to pry the cover up.
    • You will feel the cover pop up. This is normal.
  3. Toshiba Satellite L305D-S5895 RAM Replacement: 3 단계, 이미지 1/3 Toshiba Satellite L305D-S5895 RAM Replacement: 3 단계, 이미지 2/3 Toshiba Satellite L305D-S5895 RAM Replacement: 3 단계, 이미지 3/3
    • You should now be able to see two silver tabs.
    • Use two fingers to push these tabs away from each other.
    • The RAM stick should pop up at about a 30 degree angle.
  4. Toshiba Satellite L305D-S5895 RAM Replacement: 4 단계, 이미지 1/1
    • You should now be able to remove the first RAM stick by pulling it out in the direction of the long elevated side.
  5. Toshiba Satellite L305D-S5895 RAM Replacement: 5 단계, 이미지 1/3 Toshiba Satellite L305D-S5895 RAM Replacement: 5 단계, 이미지 2/3 Toshiba Satellite L305D-S5895 RAM Replacement: 5 단계, 이미지 3/3
    • You should now be able to see the second pair of tabs for the second RAM stick.
    • The second RAM stick should now be sitting at about a 30 degree angle.
  6. Toshiba Satellite L305D-S5895 RAM Replacement: 6 단계, 이미지 1/1
    • You can now remove this RAM stick by pulling on the long elevated side of the RAM stick.
결론
To reassemble your device, follow these instructions in reverse order. Make sure that you have the RAM stick in the correct orientation when attempting to put it back in place.
Daniel Matheson
회원 가입일: 10/19/16
355 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 2-8, Isaacson Fall 2016 UMass Dartmouth, Team 2-8, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S2G8
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 273
