주요 콘텐츠로 건너뛰기
Toshiba Satellite L305D-S5900 Battery Replacement
  1. Toshiba Satellite L305D-S5900 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Power off your laptop before beginning dissassembly.
    • The left-hand switch and right-hand switch boxed in red located at the bottom on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 Battery Replacement: 2 단계, 이미지 1/1
    • Set the right-hand switch near the battery into the unlock position (move switch from left to right).
  3. Toshiba Satellite L305D-S5900 Battery Replacement: 3 단계, 이미지 1/1
    • Set and hold the left hand switch near the battery into its unlock position (move switch from right to left).
  4. Toshiba Satellite L305D-S5900 Battery Replacement: 4 단계, 이미지 1/2 Toshiba Satellite L305D-S5900 Battery Replacement: 4 단계, 이미지 2/2
    • While both switches are in their unlocked positions, use a plastic opening tool or your fingers to lift out the battery at the indent between the switches.
    • The right hand switch regardless of initial position will stay or return to the unlock position when a battery is placed back in the slot. To avoid any mishaps, be sure to set the switch back into the lock position while any battery is plugged in.
결론
Sing Yang Cheng
회원 가입일: 10/20/16
501 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 UMass Dartmouth, Team 3-6, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S3G6
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 224
