주요 콘텐츠로 건너뛰기
Toshiba Satellite L305D-S5900 Keyboard Replacement
필요한 것
  1. Toshiba Satellite L305D-S5900 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Power off your laptop before beginning disassembly.
    • The plastic strip boxed in red is located above the keyboard of the computer.
  2. Toshiba Satellite L305D-S5900 Keyboard Replacement: 2 단계, 이미지 1/3 Toshiba Satellite L305D-S5900 Keyboard Replacement: 2 단계, 이미지 2/3 Toshiba Satellite L305D-S5900 Keyboard Replacement: 2 단계, 이미지 3/3
    • There are three points of contact boxed in red needed to release located at the far left, the far right and the middle of the plastic strip.
    • Remove the plastic strip from one far end progressively towards the other end using a metal spludger.
  3. Toshiba Satellite L305D-S5900 Keyboard Replacement: 3 단계, 이미지 1/2 Toshiba Satellite L305D-S5900 Keyboard Replacement: 3 단계, 이미지 2/2
    • Remove the two 5.3 mm Phillips #1 screws that are beneath the strip.
    • The screws located at the far left and far right when the plastic strip is removed.
  4. Toshiba Satellite L305D-S5900 Keyboard Replacement: 4 단계, 이미지 1/2 Toshiba Satellite L305D-S5900 Keyboard Replacement: 4 단계, 이미지 2/2
    • Use the metal spludger to push the keyboard in the direction of the track pad and then lift the keyboard up.
    • Be careful not to pull too fast as there is still another cable attaching the keyboard.
  5. Toshiba Satellite L305D-S5900 Keyboard Replacement: 5 단계, 이미지 1/3 Toshiba Satellite L305D-S5900 Keyboard Replacement: 5 단계, 이미지 2/3 Toshiba Satellite L305D-S5900 Keyboard Replacement: 5 단계, 이미지 3/3
    • There are two tab boxed in red is located at each side of the ZIF (zero insertion force) connector.
    • Use a metal spludger to push the tab upward in order to release the cable ribbon.
    • Carefully pull out the ribbon cable from the ZIF (zero insertion force) connector.
결론
Sing Yang Cheng
회원 가입일: 10/20/16
501 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 UMass Dartmouth, Team 3-6, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S3G6
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 331
