주요 콘텐츠로 건너뛰기
Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement
필요한 것
  1. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement, Optical Drive (Disk Drive): 1 단계, 이미지 1/1
    • Power off your laptop before beginning disassembly.
    • The 5.3 mm Phillips #1 screw boxed in red is located at the center on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: 2 단계, 이미지 1/2 Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: 2 단계, 이미지 2/2
    • Remove the panel that houses the RAM chips by removing the screw that secures it into its spot.
  3. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: 3 단계, 이미지 1/2 Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: 3 단계, 이미지 2/2
    • The 5.3 mm Phillips #1 screw boxed in red is located on the right panel that house the RAM on the underside of the computer.
    • Remove the screw securing the drive on the plastic edge.
  4. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: 4 단계, 이미지 1/1
    • Use a screwdriver or a metal spludgers to push the metal piece attached to the drive in the direction of the drive opens until the drive pops out of its socket.
  5. Toshiba Satellite L305D-S5900 Optical Drive (Disk Drive) Replacement: 5 단계, 이미지 1/1
    • Fully remove the drive by pulling it all the way out of its socket.
결론
Sing Yang Cheng
회원 가입일: 10/20/16
501 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 UMass Dartmouth, Team 3-6, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S3G6
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 622
