주요 콘텐츠로 건너뛰기
Toshiba Satellite L305D-S5900 RAM Replacement
필요한 것
  1. Toshiba Satellite L305D-S5900 RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Power off your laptop before beginning dissassembly.
    • The 5.3 mm Phillips #1 screw boxed in red is located at the center on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 RAM Replacement: 2 단계, 이미지 1/2 Toshiba Satellite L305D-S5900 RAM Replacement: 2 단계, 이미지 2/2
    • Remove the panel that houses the RAM chips by removing the screw that secures it into its spot.
  3. Toshiba Satellite L305D-S5900 RAM Replacement: 3 단계, 이미지 1/3 Toshiba Satellite L305D-S5900 RAM Replacement: 3 단계, 이미지 2/3 Toshiba Satellite L305D-S5900 RAM Replacement: 3 단계, 이미지 3/3
    • There are two metal holdings boxed in red is located at each side of the RAM chip (left and right).
    • Use a plastic opening tool or your fingers to carefully pull or push up from the underside of the RAM chip until it naturally sits in the socket at an angle.
    • If using too much force, push aside the metal holdings that holds on to the RAM chip on both side then attempt lifting it up
    • There are two RAM chips that can be removes. To remove the second RAM chips follow the same instructed as above.
결론
Sing Yang Cheng
회원 가입일: 10/20/16
501 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 UMass Dartmouth, Team 3-6, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S3G6
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 247
