주요 콘텐츠로 건너뛰기
Toshiba Satellite L305D-S5900 Storage Drive Replacement
필요한 것
  1. Toshiba Satellite L305D-S5900 Storage Drive Replacement, Storage Drive: 1 단계, 이미지 1/1
    • Power off your laptop before beginning disassembly.
    • Two 5.3 mm Phillips #1 screws boxed in red are located at the top right corner on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 Storage Drive Replacement: 2 단계, 이미지 1/3 Toshiba Satellite L305D-S5900 Storage Drive Replacement: 2 단계, 이미지 2/3 Toshiba Satellite L305D-S5900 Storage Drive Replacement: 2 단계, 이미지 3/3
    • Remove the panel that houses the storage drive by unscrewing the two 5.3 mm Phillips #1 screws that hold it into place
  3. Toshiba Satellite L305D-S5900 Storage Drive Replacement: 3 단계, 이미지 1/2 Toshiba Satellite L305D-S5900 Storage Drive Replacement: 3 단계, 이미지 2/2
    • The standard hard disk drive that comes with this laptop model should have a ribbon attached to it. Pull this ribbon back until the hard drive comes out of the socket.
    • If your drive doesn’t have this ribbon, it can be pushed out of place by wedging a plastic opening tool in between the drive and its socket and push it out.
결론
Sing Yang Cheng
회원 가입일: 10/20/16
501 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 UMass Dartmouth, Team 3-6, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S3G6
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 339
