주요 콘텐츠로 건너뛰기
Toshiba Satellite L305D-S5950 CD Drive Replacement
필요한 것
  1. Toshiba Satellite L305D-S5950 CD Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 CD Drive Replacement: 2 단계, 이미지 1/2 Toshiba Satellite L305D-S5950 CD Drive Replacement: 2 단계, 이미지 2/2
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 CD Drive Replacement: 3 단계, 이미지 1/2 Toshiba Satellite L305D-S5950 CD Drive Replacement: 3 단계, 이미지 2/2
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 CD Drive Replacement: 4 단계, 이미지 1/1
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 CD Drive Replacement, CD Drive: 5 단계, 이미지 1/1
    • Locate the RAM cover on the underside of the laptop.
  6. Toshiba Satellite L305D-S5950 CD Drive Replacement: 6 단계, 이미지 1/1
    • Use a phillips head #0 screwdriver to remove the screw located on the RAM cover.
  7. Toshiba Satellite L305D-S5950 CD Drive Replacement: 7 단계, 이미지 1/2 Toshiba Satellite L305D-S5950 CD Drive Replacement: 7 단계, 이미지 2/2
    • Using your fingers, carefully remove the cover.
결론
William
회원 가입일: 03/26/14
875 평판
안내서 7개 작성하였습니다
Clemson, Team 1-2, Benson Spring 2014 Clemson, Team 1-2, Benson Spring 2014 회원
CLEM-BENSON-S14S1G2
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 287
