주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
부품
지정된 부품이 없습니다.
  1. Locate the two sliding battery locks on the underside of the laptop.
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Locate the right battery lock and slide it to the right. Locate the right battery lock and slide it to the right.
    • Locate the right battery lock and slide it to the right.
  3. While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery. While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Remove the battery from the laptop.
    • Remove the battery from the laptop.
  5. Locate the RAM cover on the underside of the laptop.
    • Locate the RAM cover on the underside of the laptop.
  6. Use a phillips head #0 screwdriver to remove the screw located on the RAM cover.
    • Use a phillips head #0 screwdriver to remove the screw located on the RAM cover.
  7. Using your fingers, carefully remove the cover. Using your fingers, carefully remove the cover.
    • Using your fingers, carefully remove the cover.
결론
William
회원 가입일: 2014년 03월 26일
863 평판
안내서 7개 작성하였습니다
Clemson, Team 1-2, Benson Spring 2014 Clemson, Team 1-2, Benson Spring 2014 회원
CLEM-BENSON-S14S1G2
3 회원들
안내서 10개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 186
