주요 콘텐츠로 건너뛰기
Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement
필요한 것
  1. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: 2 단계, 이미지 1/2 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: 2 단계, 이미지 2/2
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: 3 단계, 이미지 1/2 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: 3 단계, 이미지 2/2
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: 4 단계, 이미지 1/1
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement, Hard Disk Drive: 5 단계, 이미지 1/2 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement, Hard Disk Drive: 5 단계, 이미지 2/2
    • Unscrew the screws enough to remove the top cover.
  6. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: 6 단계, 이미지 1/1
    • Remove the cover by lifting the right side up at an angle before removing the entire cover.
  7. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: 7 단계, 이미지 1/2 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: 7 단계, 이미지 2/2
    • Remove the hard drive from the SATA slot by tugging lightly on the ribbon cable to the right.
  8. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: 8 단계, 이미지 1/3 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: 8 단계, 이미지 2/3 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: 8 단계, 이미지 3/3
    • To separate the hard drive from the caddy, unscrew the two screws.
결론
Ricky Baker
회원 가입일: 03/26/14
217 평판
안내서 2개 작성하였습니다
Clemson, Team 1-2, Benson Spring 2014 Clemson, Team 1-2, Benson Spring 2014 회원
CLEM-BENSON-S14S1G2
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 864
