주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
In order to replace the motherboard the hard drive, RAM, keyboard and motherboard cover need to be removed.
  1. Locate the two sliding battery locks on the underside of the laptop.
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Locate the right battery lock and slide it to the right. Locate the right battery lock and slide it to the right.
    • Locate the right battery lock and slide it to the right.
  3. While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery. While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Remove the battery from the laptop.
    • Remove the battery from the laptop.
  5. Unscrew the screws enough to remove the top cover. Unscrew the screws enough to remove the top cover.
    • Unscrew the screws enough to remove the top cover.
  6. Remove the cover by lifting the right side up at an angle before removing the entire cover.
    • Remove the cover by lifting the right side up at an angle before removing the entire cover.
  7. Remove the hard drive from the SATA slot by tugging lightly on the ribbon cable to the right. Remove the hard drive from the SATA slot by tugging lightly on the ribbon cable to the right.
    • Remove the hard drive from the SATA slot by tugging lightly on the ribbon cable to the right.
  8. Essential Electronics Toolkit
    Small Toolkit. Big Possibilities.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  9. To separate the hard drive from the caddy, unscrew the two screws. To separate the hard drive from the caddy, unscrew the two screws. To separate the hard drive from the caddy, unscrew the two screws.
    • To separate the hard drive from the caddy, unscrew the two screws.
  10. Unscrew the RAM cover and rotate the cover up to remove it. The screw should not be fully removed from the cover itself. Unscrew the RAM cover and rotate the cover up to remove it. The screw should not be fully removed from the cover itself. Unscrew the RAM cover and rotate the cover up to remove it. The screw should not be fully removed from the cover itself.
    • Unscrew the RAM cover and rotate the cover up to remove it. The screw should not be fully removed from the cover itself.
  11. Push the small levers at the sides of the RAM module away from each other. The RAM module should automatically rotate upwards. Push the small levers at the sides of the RAM module away from each other. The RAM module should automatically rotate upwards.
    • Push the small levers at the sides of the RAM module away from each other. The RAM module should automatically rotate upwards.
  12. Remove the RAM module by pulling it out at the angle it was rotated to. Remove the RAM module by pulling it out at the angle it was rotated to.
    • Remove the RAM module by pulling it out at the angle it was rotated to.
  13. If you want to replace the second RAM module, apply steps 2 and 3 to do so. If you want to replace the second RAM module, apply steps 2 and 3 to do so. If you want to replace the second RAM module, apply steps 2 and 3 to do so.
    • If you want to replace the second RAM module, apply steps 2 and 3 to do so.
  14. Locate the plastic strip at the top of the keyboard. Use a pry tool to remove the plastic strip.
    • Locate the plastic strip at the top of the keyboard.
    • Use a pry tool to remove the plastic strip.
    • Using your hands pull out the rest of the plastic strip.
  15. Use a phillips head #0 screwdriver to remove the two  3.75mm screws holding the keyboard in place.
    • Use a phillips head #0 screwdriver to remove the two 3.75mm screws holding the keyboard in place.
  16. Lift up the top of the keyboard to remove it. Under the keyboard there is a ribbon cable connecting the keyboard to the laptop. Do not just quickly pull out the keyboard. Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
    • Lift up the top of the keyboard to remove it.
    • Under the keyboard there is a ribbon cable connecting the keyboard to the laptop. Do not just quickly pull out the keyboard.
    • Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
    • Unplug the ribbon cable from the laptop.
  17. Remove the keyboard completely from the laptop.
    • Remove the keyboard completely from the laptop.
  18. Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm. Remove all  5.25mm screws from the top of the laptop.
    • Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm.
    • Remove all 5.25mm screws from the top of the laptop.
  19. Unplug the wires highlighted with red squares. Using a pry tool and yours hands to remove the motherboard cover. Using a pry tool and yours hands to remove the motherboard cover.
    • Unplug the wires highlighted with red squares.
    • Using a pry tool and yours hands to remove the motherboard cover.
  20. Unscrew all the screws indicated by the red circles (The bottom two screws are 10.75mm and the top screw is 5mm).
    • Unscrew all the screws indicated by the red circles (The bottom two screws are 10.75mm and the top screw is 5mm).
    • Unplug all the wires indicated by the orange squares.
    • Some wires may have a lock on them that needs to be pulled out before the wire is removed.
  21. At this point the motherboard can be fully removed from the laptop.
    • At this point the motherboard can be fully removed from the laptop.
결론
다른 4명이 해당 안내서를 완성하였습니다.
William
회원 가입일: 2014년 03월 26일
863 평판
안내서 7개 작성하였습니다
Clemson, Team 1-2, Benson Spring 2014 Clemson, Team 1-2, Benson Spring 2014 회원
CLEM-BENSON-S14S1G2
3 회원들
안내서 10개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 27
전체 시간: 1,626
