주요 콘텐츠로 건너뛰기
Toshiba Satellite L305D-S5950 RAM Replacement
필요한 것
  1. Toshiba Satellite L305D-S5950 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 RAM Replacement: 2 단계, 이미지 1/2 Toshiba Satellite L305D-S5950 RAM Replacement: 2 단계, 이미지 2/2
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 RAM Replacement: 3 단계, 이미지 1/2 Toshiba Satellite L305D-S5950 RAM Replacement: 3 단계, 이미지 2/2
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 RAM Replacement: 4 단계, 이미지 1/1
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 RAM Replacement, RAM: 5 단계, 이미지 1/3 Toshiba Satellite L305D-S5950 RAM Replacement, RAM: 5 단계, 이미지 2/3 Toshiba Satellite L305D-S5950 RAM Replacement, RAM: 5 단계, 이미지 3/3
    • Unscrew the RAM cover and rotate the cover up to remove it. The screw should not be fully removed from the cover itself.
  6. Toshiba Satellite L305D-S5950 RAM Replacement: 6 단계, 이미지 1/2 Toshiba Satellite L305D-S5950 RAM Replacement: 6 단계, 이미지 2/2
    • Push the small levers at the sides of the RAM module away from each other. The RAM module should automatically rotate upwards.
  7. Toshiba Satellite L305D-S5950 RAM Replacement: 7 단계, 이미지 1/2 Toshiba Satellite L305D-S5950 RAM Replacement: 7 단계, 이미지 2/2
    • Remove the RAM module by pulling it out at the angle it was rotated to.
  8. Toshiba Satellite L305D-S5950 RAM Replacement: 8 단계, 이미지 1/3 Toshiba Satellite L305D-S5950 RAM Replacement: 8 단계, 이미지 2/3 Toshiba Satellite L305D-S5950 RAM Replacement: 8 단계, 이미지 3/3
    • If you want to replace the second RAM module, apply steps 2 and 3 to do so.
결론
To reassemble your device, follow these instructions in reverse order. When placing the RAM chips in, push them down until the levers snap into place after inserting them into the slot.
Ricky Baker
회원 가입일: 03/26/14
217 평판
안내서 2개 작성하였습니다
Clemson, Team 1-2, Benson Spring 2014 Clemson, Team 1-2, Benson Spring 2014 회원
CLEM-BENSON-S14S1G2
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 412
