이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
Unscrew the RAM cover and rotate the cover up to remove it. The screw should not be fully removed from the cover itself.
Push the small levers at the sides of the RAM module away from each other. The RAM module should automatically rotate upwards.
Remove the RAM module by pulling it out at the angle it was rotated to.
If you want to replace the second RAM module, apply steps 2 and 3 to do so.
