주요 콘텐츠로 건너뛰기
Toshiba Satellite L305D-S5950 Speaker Replacement
필요한 것
  1. Toshiba Satellite L305D-S5950 Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 Speaker Replacement: 2 단계, 이미지 1/2 Toshiba Satellite L305D-S5950 Speaker Replacement: 2 단계, 이미지 2/2
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 Speaker Replacement: 3 단계, 이미지 1/2 Toshiba Satellite L305D-S5950 Speaker Replacement: 3 단계, 이미지 2/2
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 Speaker Replacement: 4 단계, 이미지 1/1
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 Speaker Replacement, Keyboard: 5 단계, 이미지 1/2 Toshiba Satellite L305D-S5950 Speaker Replacement, Keyboard: 5 단계, 이미지 2/2
    • Locate the plastic strip at the top of the keyboard.
    • Use a pry tool to remove the plastic strip.
    • Using your hands pull out the rest of the plastic strip.
  6. Toshiba Satellite L305D-S5950 Speaker Replacement: 6 단계, 이미지 1/1
    • Use a phillips head #0 screwdriver to remove the two 3.75mm screws holding the keyboard in place.
  7. Toshiba Satellite L305D-S5950 Speaker Replacement: 7 단계, 이미지 1/3 Toshiba Satellite L305D-S5950 Speaker Replacement: 7 단계, 이미지 2/3 Toshiba Satellite L305D-S5950 Speaker Replacement: 7 단계, 이미지 3/3
    • Lift up the top of the keyboard to remove it.
    • Under the keyboard there is a ribbon cable connecting the keyboard to the laptop. Do not just quickly pull out the keyboard.
    • Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
    • Unplug the ribbon cable from the laptop.
  8. Toshiba Satellite L305D-S5950 Speaker Replacement: 8 단계, 이미지 1/1
    • Remove the keyboard completely from the laptop.
  9. Toshiba Satellite L305D-S5950 Speaker Replacement, Motherboard Cover: 9 단계, 이미지 1/2 Toshiba Satellite L305D-S5950 Speaker Replacement, Motherboard Cover: 9 단계, 이미지 2/2
    • Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm.
    • Remove all 5.25mm screws from the top of the laptop.
  10. Toshiba Satellite L305D-S5950 Speaker Replacement: 10 단계, 이미지 1/3 Toshiba Satellite L305D-S5950 Speaker Replacement: 10 단계, 이미지 2/3 Toshiba Satellite L305D-S5950 Speaker Replacement: 10 단계, 이미지 3/3
    • Unplug the wires highlighted with red squares.
    • Using a pry tool and yours hands to remove the motherboard cover.
  11. Toshiba Satellite L305D-S5950 Speaker Replacement, Speaker: 11 단계, 이미지 1/2 Toshiba Satellite L305D-S5950 Speaker Replacement, Speaker: 11 단계, 이미지 2/2
    • Use a phillips head #00 screwdriver to remove the two 5.25mm screws.
  12. Toshiba Satellite L305D-S5950 Speaker Replacement: 12 단계, 이미지 1/2 Toshiba Satellite L305D-S5950 Speaker Replacement: 12 단계, 이미지 2/2
    • Turn the keyboard housing over and disconnect the speaker power wire from the keyboard housing.
    • Remove both speakers.
결론
William
회원 가입일: 03/26/14
875 평판
안내서 7개 작성하였습니다
Clemson, Team 1-2, Benson Spring 2014 Clemson, Team 1-2, Benson Spring 2014 회원
CLEM-BENSON-S14S1G2
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 303
