이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
In order to replace the speakers on your device the keyboard and motherboard cover need to be removed first.
필요한 것
Locate the plastic strip at the top of the keyboard.
Use a pry tool to remove the plastic strip.
Using your hands pull out the rest of the plastic strip.
Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm.
Remove all 5.25mm screws from the top of the laptop.
거의 끝나갑니다!
결론
