주요 콘텐츠로 건너뛰기
Toshiba Satellite L35-S2174 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite L35-S2174 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the laptop off to prevent the possibility of electric shock or damage to the computer.
    • Flip the laptop so that the bottom is facing upwards.
  2. Toshiba Satellite L35-S2174 Hard Drive Replacement: 2 단계, 이미지 1/2 Toshiba Satellite L35-S2174 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Slide the battery lock switch to the left.
  3. Toshiba Satellite L35-S2174 Hard Drive Replacement: 3 단계, 이미지 1/2 Toshiba Satellite L35-S2174 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Pull the sliding switch to the right and continue to hold it in this position.
  4. Toshiba Satellite L35-S2174 Hard Drive Replacement: 4 단계, 이미지 1/1
    • While holding the switch, slide the battery away from you.
    • You do not need to hold the switch when putting the battery back into the laptop.
  5. Toshiba Satellite L35-S2174 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1/3 Toshiba Satellite L35-S2174 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 2/3 Toshiba Satellite L35-S2174 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 3/3
    • Use a J1 screwdriver to unscrew the two circled screws. The screws will remain attached to the plastic panel.
    • Lift the panel and remove it from the laptop.
  6. Toshiba Satellite L35-S2174 Hard Drive Replacement: 6 단계, 이미지 1/2 Toshiba Satellite L35-S2174 Hard Drive Replacement: 6 단계, 이미지 2/2
    • Slide the hard drive to the left to detach it from the computer.
    • Lift the hard drive from the computer.
결론
Amani Mitchell
회원 가입일: 10/18/16
401 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 1-4, Catania Fall 2016 UMass Dartmouth, Team 1-4, Catania Fall 2016 회원
UMASSD-CATANIA-F16S1G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 561
