주요 콘텐츠로 건너뛰기
Toshiba Satellite L35-S2174 Keyboard Replacement
필요한 것
  1. Toshiba Satellite L35-S2174 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the laptop off to prevent the possibility of electric shock or damage to the computer.
    • Flip the laptop so that the bottom is facing upwards.
  2. Toshiba Satellite L35-S2174 Keyboard Replacement: 2 단계, 이미지 1/2 Toshiba Satellite L35-S2174 Keyboard Replacement: 2 단계, 이미지 2/2
    • Slide the battery lock switch to the left.
  3. Toshiba Satellite L35-S2174 Keyboard Replacement: 3 단계, 이미지 1/2 Toshiba Satellite L35-S2174 Keyboard Replacement: 3 단계, 이미지 2/2
    • Pull the sliding switch to the right and continue to hold it in this position.
  4. Toshiba Satellite L35-S2174 Keyboard Replacement: 4 단계, 이미지 1/1
    • While holding the switch, slide the battery away from you.
    • You do not need to hold the switch when putting the battery back into the laptop.
  5. Toshiba Satellite L35-S2174 Keyboard Replacement, Keyboard: 5 단계, 이미지 1/2 Toshiba Satellite L35-S2174 Keyboard Replacement, Keyboard: 5 단계, 이미지 2/2
    • Remove the two circled 4mm screws with a J1 screwdriver.
  6. Toshiba Satellite L35-S2174 Keyboard Replacement: 6 단계, 이미지 1/2 Toshiba Satellite L35-S2174 Keyboard Replacement: 6 단계, 이미지 2/2
    • Remove the two circled 5mm screws with a J1 screwdriver.
  7. Toshiba Satellite L35-S2174 Keyboard Replacement: 7 단계, 이미지 1/2 Toshiba Satellite L35-S2174 Keyboard Replacement: 7 단계, 이미지 2/2
    • Use a spudger to pry up the plastic panel between the keyboard the screen.
    • Repeat on opposite side of laptop.
    • The panel may be difficult to remove.
    • Tilt the laptop's screen back.
    • Lift the panel and remove it from the laptop.
  8. Toshiba Satellite L35-S2174 Keyboard Replacement: 8 단계, 이미지 1/2 Toshiba Satellite L35-S2174 Keyboard Replacement: 8 단계, 이미지 2/2
    • There is a ribbon cable underneath the keyboard. Don't lift the keyboard too forcefully or you may break the ribbon cable.
    • Unclip the keyboard from the laptop by lifting it.
    • Slide the keyboard slightly towards the screen.
    • Lift the keyboard out of the way.
  9. Toshiba Satellite L35-S2174 Keyboard Replacement: 9 단계, 이미지 1/1
    • Pull the ribbon cable straight out of the connector.
    • To reinstall the cable, hold it near the end and push it straight into the connector, being careful not to kink the cable.
결론
Amani Mitchell
회원 가입일: 10/18/16
401 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 1-4, Catania Fall 2016 UMass Dartmouth, Team 1-4, Catania Fall 2016 회원
UMASSD-CATANIA-F16S1G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 337
