소개
The Power Jack for the Toshiba Satellite L355/L305 series is damaged after many uses and will most likely need to be replaced. In this guide you will find a permanent solution to the common problem.
In order to repair/replace the Power Jack it is necessary to disassemble the laptop.
필요한 것
거의 끝나갑니다!
결론
다른 7명이 해당 안내서를 완성하였습니다.
