주요 콘텐츠로 건너뛰기
Toshiba Satellite L40-A Fan Assembly Replacement
필요한 것
  1. Toshiba Satellite L40-A Fan Assembly Replacement, Fan Assembly: 1 단계, 이미지 1/1
    • Flip open the laptop to access the back panel.
  2. Toshiba Satellite L40-A Fan Assembly Replacement: 2 단계, 이미지 1/1
    • Use a Philips #0 screwdriver to unscrew the back panel.
  3. Toshiba Satellite L40-A Fan Assembly Replacement: 3 단계, 이미지 1/1
    • Use an opening tool to remove the back panel from the laptop.
  4. Toshiba Satellite L40-A Fan Assembly Replacement: 4 단계, 이미지 1/1
    • Disconnect the wire connecting the fan assembly.
  5. Toshiba Satellite L40-A Fan Assembly Replacement: 5 단계, 이미지 1/1
    • Unscrew the screws on located on the edges of the fan.
  6. Toshiba Satellite L40-A Fan Assembly Replacement: 6 단계, 이미지 1/1
    • Carefully lift the fan out of the laptop.
결론
Emiliano Hernandez
회원 가입일: 10/11/22
385 평판
안내서 3개 작성하였습니다
University of North Texas, Team 3-3, Saru Jimmy Fall 2022 University of North Texas, Team 3-3, Saru Jimmy Fall 2022 회원
UNT-SARU JIMMY-F22S3G3
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 131
