소개
The bottom access panel is designed to be quickly and easily removed to allow the consumer quick access to components of the the computer including RAM, the wireless card, and the dial up modem. This panel requires only the the removal of a five screws to gain the user access.
부품
No parts specified.
  1. Make sure the battery lock switch is switched to the unlocked position. The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock. The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Slide the battery release switch to the left. The switch is spring loaded, so you must hold the switch in place while removing the battery.
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Using a finger, lift up the battery. The battery release switch must be held in place.
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  5. Remove the 5 Phillips screws holding the panel in place. These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss. These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss.
    • Remove the 5 Phillips screws holding the panel in place.
    • These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss.
  6. Use a finger to remove the panel by lifting up on the provided removal tab. Use a finger to remove the panel by lifting up on the provided removal tab. Use a finger to remove the panel by lifting up on the provided removal tab.
    • Use a finger to remove the panel by lifting up on the provided removal tab.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Stephen Sippel
회원 가입일: 2013년 04월 16일
167 평판
안내서 9개 작성하였습니다
Cal Poly, Team 21-54, Johann Spring 2013 Cal Poly, Team 21-54, Johann Spring 2013 회원
CPSU-JOHANN-S13S21G54
4 회원들
안내서 9개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 685
