주요 콘텐츠로 건너뛰기
Toshiba Satellite L45-S7423 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite L45-S7423 Hard Drive Replacement, Battery: 1 단계, 이미지 1/3 Toshiba Satellite L45-S7423 Hard Drive Replacement, Battery: 1 단계, 이미지 2/3 Toshiba Satellite L45-S7423 Hard Drive Replacement, Battery: 1 단계, 이미지 3/3
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 Hard Drive Replacement: 2 단계, 이미지 1/2 Toshiba Satellite L45-S7423 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 Hard Drive Replacement: 3 단계, 이미지 1/2 Toshiba Satellite L45-S7423 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. Toshiba Satellite L45-S7423 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/3 Toshiba Satellite L45-S7423 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2/3 Toshiba Satellite L45-S7423 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 3/3
    • Remove the two Phillips screws holding the panel in place.
    • These screws cannot be removed completely from the panel. They are fastened to the panel to avoid loss.
  5. Toshiba Satellite L45-S7423 Hard Drive Replacement: 5 단계, 이미지 1/1
    • To remove, lift up the panel's tab.
  6. Toshiba Satellite L45-S7423 Hard Drive Replacement: 6 단계, 이미지 1/3 Toshiba Satellite L45-S7423 Hard Drive Replacement: 6 단계, 이미지 2/3 Toshiba Satellite L45-S7423 Hard Drive Replacement: 6 단계, 이미지 3/3
    • Remove the screws attaching the hard drive and bracket.
    • Four 4.6 mm Phillips screws.
  7. Toshiba Satellite L45-S7423 Hard Drive Replacement: 7 단계, 이미지 1/3 Toshiba Satellite L45-S7423 Hard Drive Replacement: 7 단계, 이미지 2/3 Toshiba Satellite L45-S7423 Hard Drive Replacement: 7 단계, 이미지 3/3
    • Lift up the black tab to expose hard drive.
    • Grab the hard drive bracket and pull to remove.
  8. Toshiba Satellite L45-S7423 Hard Drive Replacement: 8 단계, 이미지 1/2 Toshiba Satellite L45-S7423 Hard Drive Replacement: 8 단계, 이미지 2/2
    • Remove the screws attaching the hard drive to hard drive bracket.
    • Four 3.6 mm Phillips screws.
  9. Toshiba Satellite L45-S7423 Hard Drive Replacement: 9 단계, 이미지 1/2 Toshiba Satellite L45-S7423 Hard Drive Replacement: 9 단계, 이미지 2/2
    • Separate the hard drive from hard drive bracket to complete removal.
결론
Stephen Sippel
회원 가입일: 04/16/13
194 평판
안내서 9개 작성하였습니다
Cal Poly, Team 21-54, Johann Spring 2013 Cal Poly, Team 21-54, Johann Spring 2013 회원
CPSU-JOHANN-S13S21G54
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 1,655
