주요 콘텐츠로 건너뛰기
Toshiba Satellite L45-S7423 Keyboard Replacement
필요한 것
  1. Toshiba Satellite L45-S7423 Keyboard Replacement, Battery: 1 단계, 이미지 1/3 Toshiba Satellite L45-S7423 Keyboard Replacement, Battery: 1 단계, 이미지 2/3 Toshiba Satellite L45-S7423 Keyboard Replacement, Battery: 1 단계, 이미지 3/3
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 Keyboard Replacement: 2 단계, 이미지 1/2 Toshiba Satellite L45-S7423 Keyboard Replacement: 2 단계, 이미지 2/2
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 Keyboard Replacement: 3 단계, 이미지 1/2 Toshiba Satellite L45-S7423 Keyboard Replacement: 3 단계, 이미지 2/2
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. Toshiba Satellite L45-S7423 Keyboard Replacement, Bottom Access Panel: 4 단계, 이미지 1/3 Toshiba Satellite L45-S7423 Keyboard Replacement, Bottom Access Panel: 4 단계, 이미지 2/3 Toshiba Satellite L45-S7423 Keyboard Replacement, Bottom Access Panel: 4 단계, 이미지 3/3
    • Remove the 5 Phillips screws holding the panel in place.
    • These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss.
  5. Toshiba Satellite L45-S7423 Keyboard Replacement: 5 단계, 이미지 1/3 Toshiba Satellite L45-S7423 Keyboard Replacement: 5 단계, 이미지 2/3 Toshiba Satellite L45-S7423 Keyboard Replacement: 5 단계, 이미지 3/3
    • Use a finger to remove the panel by lifting up on the provided removal tab.
  6. Toshiba Satellite L45-S7423 Keyboard Replacement, Keyboard: 6 단계, 이미지 1/3 Toshiba Satellite L45-S7423 Keyboard Replacement, Keyboard: 6 단계, 이미지 2/3 Toshiba Satellite L45-S7423 Keyboard Replacement, Keyboard: 6 단계, 이미지 3/3
    • Remove the two screws holding the keyboard in place.
    • Two 5.7 mm Phillips screws.
    • 'KB' is written alongside the screw holes. This indicates the screws hold the keyboard in place.
  7. Toshiba Satellite L45-S7423 Keyboard Replacement: 7 단계, 이미지 1/3 Toshiba Satellite L45-S7423 Keyboard Replacement: 7 단계, 이미지 2/3 Toshiba Satellite L45-S7423 Keyboard Replacement: 7 단계, 이미지 3/3
    • There are three tabs holding the keyboard in place.
    • They are located under the ESC, F8, and DEL keys.
    • Expose the tabs by pressing down on adjacent keys.
  8. Toshiba Satellite L45-S7423 Keyboard Replacement: 8 단계, 이미지 1/3 Toshiba Satellite L45-S7423 Keyboard Replacement: 8 단계, 이미지 2/3 Toshiba Satellite L45-S7423 Keyboard Replacement: 8 단계, 이미지 3/3
    • While you press down the ESC key, push the tab with the spudger to release that side of the keyboard.
    • Use a finger to prevent the keyboard from locking back in place.
    • Repeat the previous step for the tabs under the F8 and DEL keys.
  9. Toshiba Satellite L45-S7423 Keyboard Replacement: 9 단계, 이미지 1/3 Toshiba Satellite L45-S7423 Keyboard Replacement: 9 단계, 이미지 2/3 Toshiba Satellite L45-S7423 Keyboard Replacement: 9 단계, 이미지 3/3
    • Pick up the keyboard. This exposes a cable that connects the keyboard to the laptop.
    • Lift the keyboard gently. The cable connecting it to the computer is a ribbon. If pulled too hard, the ribbon may be damaged.
  10. Toshiba Satellite L45-S7423 Keyboard Replacement: 10 단계, 이미지 1/2 Toshiba Satellite L45-S7423 Keyboard Replacement: 10 단계, 이미지 2/2
    • Gently unplug the ribbon cable connecting the keyboard to the laptop by pulling horizontally.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Stephen Sippel
회원 가입일: 04/16/13
194 평판
안내서 9개 작성하였습니다
Cal Poly, Team 21-54, Johann Spring 2013 Cal Poly, Team 21-54, Johann Spring 2013 회원
CPSU-JOHANN-S13S21G54
4 회원들
안내서 18개 작성하였습니다
댓글 한 개
Great instuctions plus photos. Spot on, tx
Darrell - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 19
전체 시간: 3,188
