주요 콘텐츠로 건너뛰기
Toshiba Satellite L45-S7423 LCD Display Replacement
필요한 것
  1. Toshiba Satellite L45-S7423 LCD Display Replacement, Battery: 1 단계, 이미지 1/3 Toshiba Satellite L45-S7423 LCD Display Replacement, Battery: 1 단계, 이미지 2/3 Toshiba Satellite L45-S7423 LCD Display Replacement, Battery: 1 단계, 이미지 3/3
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 LCD Display Replacement: 2 단계, 이미지 1/2 Toshiba Satellite L45-S7423 LCD Display Replacement: 2 단계, 이미지 2/2
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 LCD Display Replacement: 3 단계, 이미지 1/2 Toshiba Satellite L45-S7423 LCD Display Replacement: 3 단계, 이미지 2/2
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. Toshiba Satellite L45-S7423 LCD Display Replacement, Bottom Access Panel: 4 단계, 이미지 1/3 Toshiba Satellite L45-S7423 LCD Display Replacement, Bottom Access Panel: 4 단계, 이미지 2/3 Toshiba Satellite L45-S7423 LCD Display Replacement, Bottom Access Panel: 4 단계, 이미지 3/3
    • Remove the 5 Phillips screws holding the panel in place.
    • These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss.
  5. Toshiba Satellite L45-S7423 LCD Display Replacement: 5 단계, 이미지 1/3 Toshiba Satellite L45-S7423 LCD Display Replacement: 5 단계, 이미지 2/3 Toshiba Satellite L45-S7423 LCD Display Replacement: 5 단계, 이미지 3/3
    • Use a finger to remove the panel by lifting up on the provided removal tab.
  6. Toshiba Satellite L45-S7423 LCD Display Replacement, LCD Display: 6 단계, 이미지 1/3 Toshiba Satellite L45-S7423 LCD Display Replacement, LCD Display: 6 단계, 이미지 2/3 Toshiba Satellite L45-S7423 LCD Display Replacement, LCD Display: 6 단계, 이미지 3/3
    • Remove the Phillips screw holding the panel in place and then use a finger to remove the panel.
    • This screw is not designed to be completely removed, it is permanently fastened to the panel to avoid loss.
  7. Toshiba Satellite L45-S7423 LCD Display Replacement: 7 단계, 이미지 1/3 Toshiba Satellite L45-S7423 LCD Display Replacement: 7 단계, 이미지 2/3 Toshiba Satellite L45-S7423 LCD Display Replacement: 7 단계, 이미지 3/3
    • With the aid of a plastic removal, disconnect the two wires attached to the wireless card.
  8. Toshiba Satellite L45-S7423 LCD Display Replacement: 8 단계, 이미지 1/1
    • Remove the yellow tape holding the black and the white wires in place.
  9. Toshiba Satellite L45-S7423 LCD Display Replacement: 9 단계, 이미지 1/3 Toshiba Satellite L45-S7423 LCD Display Replacement: 9 단계, 이미지 2/3 Toshiba Satellite L45-S7423 LCD Display Replacement: 9 단계, 이미지 3/3
    • Unwind the wires from the plastic tabs holding the wires in place.
  10. Toshiba Satellite L45-S7423 LCD Display Replacement: 10 단계, 이미지 1/2 Toshiba Satellite L45-S7423 LCD Display Replacement: 10 단계, 이미지 2/2
    • Remove the screw holding the ground cable in place.
    • One 4.5 mm Phillips screw.
  11. Toshiba Satellite L45-S7423 LCD Display Replacement: 11 단계, 이미지 1/2 Toshiba Satellite L45-S7423 LCD Display Replacement: 11 단계, 이미지 2/2
    • Disconnect the video cable connecting the display to the base of the laptop.
  12. Toshiba Satellite L45-S7423 LCD Display Replacement: 12 단계, 이미지 1/3 Toshiba Satellite L45-S7423 LCD Display Replacement: 12 단계, 이미지 2/3 Toshiba Satellite L45-S7423 LCD Display Replacement: 12 단계, 이미지 3/3
    • Pop off the laptop's hinge covers using a spudger tool.
    • Only a small amount of force is required. Excessive force may permanently damage the hinge covers.
  13. Toshiba Satellite L45-S7423 LCD Display Replacement: 13 단계, 이미지 1/2 Toshiba Satellite L45-S7423 LCD Display Replacement: 13 단계, 이미지 2/2
    • Remove the two screws on the back side of the laptop holding the LCD display in place.
    • Two 8.5 mm Phillips screws.
  14. Toshiba Satellite L45-S7423 LCD Display Replacement: 14 단계, 이미지 1/2 Toshiba Satellite L45-S7423 LCD Display Replacement: 14 단계, 이미지 2/2
    • Remove the final two screws on the bottom side of the laptop holding the LCD display in place.
  15. Toshiba Satellite L45-S7423 LCD Display Replacement: 15 단계, 이미지 1/3 Toshiba Satellite L45-S7423 LCD Display Replacement: 15 단계, 이미지 2/3 Toshiba Satellite L45-S7423 LCD Display Replacement: 15 단계, 이미지 3/3
    • Carefully pull apart the LCD display from the base by pulling vertically upwards on the display.
    • Be careful as you remove the display not to pull too hard on the cables as they pass through the opening.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Stephen Sippel
회원 가입일: 04/16/13
194 평판
안내서 9개 작성하였습니다
Cal Poly, Team 21-54, Johann Spring 2013 Cal Poly, Team 21-54, Johann Spring 2013 회원
CPSU-JOHANN-S13S21G54
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 15
전체 시간: 1,890
