주요 콘텐츠로 건너뛰기
Toshiba Satellite L455-S5046 Hard-drive Replacement
필요한 것
  1. Toshiba Satellite L455-S5046 Hard-drive Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite L455-S5046 Hard-drive Replacement, Battery: 1 단계, 이미지 2/2
    • Find the battery on the back of the computer. Slide both tabs outward towards the side of the laptop and the battery will come loose.
    • Insert your finger under the middle tab and lift the battery out.
  2. Toshiba Satellite L455-S5046 Hard-drive Replacement, Hard-drive: 2 단계, 이미지 1/1
    • Locate the hard drive in the upper right corner on the back of the computer.
    • Unscrew the 2 Phillips #0 7-mm screws holding the cover in place and remove the cover.
  3. Toshiba Satellite L455-S5046 Hard-drive Replacement: 3 단계, 이미지 1/1
    • Once the cover is off, the hard drive will be exposed, carefully pull it out to the right.
결론
Daryl Spurgeon
회원 가입일: 01/10/17
610 평판
안내서 6개 작성하였습니다
Oakland University, Team 2-1, Ruskiewicz Winter 2017 Oakland University, Team 2-1, Ruskiewicz Winter 2017 회원
OAK-RUSKIEWICZ-W17S2G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 279
