주요 콘텐츠로 건너뛰기
Toshiba Satellite L455-S5046 Keyboard Replacement
필요한 것
  1. Toshiba Satellite L455-S5046 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/3 Toshiba Satellite L455-S5046 Keyboard Replacement, Keyboard: 1 단계, 이미지 2/3 Toshiba Satellite L455-S5046 Keyboard Replacement, Keyboard: 1 단계, 이미지 3/3
    • Lift the plastic strip above the keyboard. If you use a lever to pick up the left edge it should pop off.
    • Use the Phillips #0 screwdriver to remove the two indicated 5-mm screws.
  2. Toshiba Satellite L455-S5046 Keyboard Replacement: 2 단계, 이미지 1/2 Toshiba Satellite L455-S5046 Keyboard Replacement: 2 단계, 이미지 2/2
    • Remove the keyboard slowly. It will be attached to the laptop by a plastic connector, which can be disconnected from the laptop by pulling gently.
결론
Daryl Spurgeon
회원 가입일: 01/10/17
610 평판
안내서 6개 작성하였습니다
Oakland University, Team 2-1, Ruskiewicz Winter 2017 Oakland University, Team 2-1, Ruskiewicz Winter 2017 회원
OAK-RUSKIEWICZ-W17S2G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 382
