주요 콘텐츠로 건너뛰기
Toshiba Satellite L455-S5046 Optical Drive Replacement
필요한 것
동영상 개요
  1. Toshiba Satellite L455-S5046 Optical Drive Replacement, Optical Drive: 1 단계, 이미지 1/1
    • Unscrew 1 Phillips #0 7-mm screw on the back of the computer.
  2. Toshiba Satellite L455-S5046 Optical Drive Replacement: 2 단계, 이미지 1/1
    • Lift the plate and gently pull it away from yourself, until it is removed.
  3. Toshiba Satellite L455-S5046 Optical Drive Replacement: 3 단계, 이미지 1/1
    • Unscrew the 1 Phillips #0 7-mm screw, located on the right side where the silver tabs of the optical drive poke out.
  4. Toshiba Satellite L455-S5046 Optical Drive Replacement: 4 단계, 이미지 1/2 Toshiba Satellite L455-S5046 Optical Drive Replacement: 4 단계, 이미지 2/2
    • The optical drive is partially visible and push it to the right.
    • The optical drive should pop out on the right side, and you can gently pull it out.
결론
Daryl Spurgeon
회원 가입일: 01/10/17
610 평판
안내서 6개 작성하였습니다
Oakland University, Team 2-1, Ruskiewicz Winter 2017 Oakland University, Team 2-1, Ruskiewicz Winter 2017 회원
OAK-RUSKIEWICZ-W17S2G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 173
