주요 콘텐츠로 건너뛰기
Toshiba Satellite L455-S5046 The Fan Replacement
필요한 것
  1. Toshiba Satellite L455-S5046 The Fan Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite L455-S5046 The Fan Replacement, Battery: 1 단계, 이미지 2/2
    • Find the battery on the back of the computer. Slide both tabs outward towards the side of the laptop and the battery will come loose.
    • Insert your finger under the middle tab and lift the battery out.
  2. Toshiba Satellite L455-S5046 The Fan Replacement, Fan: 2 단계, 이미지 1/1
    • Start on the back and unscrew the 12 Phillips #0 11-mm screws holding the back cover down.
  3. Toshiba Satellite L455-S5046 The Fan Replacement: 3 단계, 이미지 1/1
    • Pop off the hard drive cover, and then unscrew the four 11-mm Phillips #0 screws.
  4. Toshiba Satellite L455-S5046 The Fan Replacement: 4 단계, 이미지 1/2 Toshiba Satellite L455-S5046 The Fan Replacement: 4 단계, 이미지 2/2
    • Flip the laptop over. Remove the keyboard as instructed in the keyboard replacement guide.
    • Gently remove the connector visible in the upper right hand corner of the laptop by pulling to the right.
    • Remove the cover slowly. There will be two other connectors on the underside that can be removed by pulling gently.
  5. Toshiba Satellite L455-S5046 The Fan Replacement: 5 단계, 이미지 1/2 Toshiba Satellite L455-S5046 The Fan Replacement: 5 단계, 이미지 2/2
    • Remove the connector between the fan and the laptop by pulling gently to the left.
    • Remove the two indicated 11-mm Phillips #0 screws.
  6. Toshiba Satellite L455-S5046 The Fan Replacement: 6 단계, 이미지 1/1
    • Now gently lift the fan and pull out.
결론
Daryl Spurgeon
회원 가입일: 01/10/17
610 평판
안내서 6개 작성하였습니다
Oakland University, Team 2-1, Ruskiewicz Winter 2017 Oakland University, Team 2-1, Ruskiewicz Winter 2017 회원
OAK-RUSKIEWICZ-W17S2G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 258
