이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use the flat edge of the plastic opening tool to pry open the narrow plastic strip above the keyboard.
Disconnect the keyboard cable that is still attached to the keyboard.
Unlatch the fastener.
Using your hands, pull the keyboard connector out, not up.
Flip the laptop over to access the battery.
Remove the battery by sliding fingers away from each other and lifting up the tab at the same time.
Remove the twelve 10mm screws with a Phillips #00 screwdriver.
Remove the cover over the hard drive (upper right in photo) and remove the four 10mm screws at the four corners.
Flip the laptop over so it's in the right-side-up position.
Lift the grey plastic casing up and unhook any wires attached to the casing.
Remove the five 10mm screws, each with a label 'F10' next to them.
Disconnect the flat thin wire connecting the track pad to the motherboard by pulling it straight out.
Disconnect the thin red wire on the right side of the motherboard.
Disconnect the red and yellow wires connecting the fan to the motherboard by pulling the wires straight out.
Remove the fan.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
I've taken my Toshiba L455 apart a few times from watching a few different You Tube videos. I WISH I would've seen THIS site & demonstration then! It makes it SO MUCH easier by actually showing each & ALL of the screws that need to come out,It tells you in GREAT detail step by step of everything you need to do so that nothing's ruined in the process! In the videos like when it comes to removing the keyboard/ribbon for it,you can't see what they're doing when removing the ribbon,which was my hardest part! I actually had it all put back together to learn it wasn't put back together right(since I wasn't exactly sure how it came off!) After 3 times,I FINALLY figured it out,by myself! So even this 1 doesn't say that the white clip that comes out 2 release the ribbon goes back UNDER the ribbon when putting it back! Cuz mine came out fast so I missed how it was even in there. Hopefully this helps someone since I SO wished I had this! Lol!
