주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
This guide is useful for replacing a broken keyboard on your Toshiba Satellite L455-S5975. In this replacement guide, you will remove the old keyboard and install the new one.
Note: Before starting any removal or installation, remember to turn off the device and to remove it from the power source.
부품
지정된 부품이 없습니다.
  1. Before repairing your laptop, power down the system, disconnect the charger if necessary and remove the battery. Use the flat edge of the plastic opening tool to pry open the narrow plastic strip above the keyboard.
    • Before repairing your laptop, power down the system, disconnect the charger if necessary and remove the battery.
    • Use the flat edge of the plastic opening tool to pry open the narrow plastic strip above the keyboard.
  2. Remove the three 3mm screws with a Phillips#00 Screwdriver.
    • Remove the three 3mm screws with a Phillips#00 Screwdriver.
  3. Manta(만타) 드라이버 키트
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta(만타) 드라이버 키트
  4. Lift the keyboard away from the top side of the laptop.
    • Lift the keyboard away from the top side of the laptop.
    • Do not pull the keyboard away too hard. It is still connected by the fragile ribbon cable (shown in the red square).
  5. Disconnect the keyboard cable that is still attached to the keyboard. Unlatch the fastener.
    • Disconnect the keyboard cable that is still attached to the keyboard.
    • Unlatch the fastener.
    • Using your hands, pull the keyboard connector out, not up.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mike Kennedy
회원 가입일: 2013년 04월 18일
151 평판
안내서 4개 작성하였습니다
Cal Poly, Team 2-21, Maness Spring 2013 Cal Poly, Team 2-21, Maness Spring 2013 회원
CPSU-MANESS-S13S2G21
4 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 12
전체 시간: 2,043
