주요 콘텐츠로 건너뛰기
Toshiba Satellite L455-S5975 WiFi Card Replacement
필요한 것
  1. Toshiba Satellite L455-S5975 WiFi Card Replacement, WiFi Card: 1 단계, 이미지 1/1
    • Flip Laptop into an upside-down position.
    • Push latches (indicated in red) outward.
    • Lift battery by notch (indicated in green) to remove.
  2. Toshiba Satellite L455-S5975 WiFi Card Replacement: 2 단계, 이미지 1/2 Toshiba Satellite L455-S5975 WiFi Card Replacement: 2 단계, 이미지 2/2
    • Remove the plastic cover closest to the battery by first unscrewing the single 7mm screw (in red) with the phillips #00 screwdriver.
    • Now, lift the cover by the notch under the screw (in red) using a plastic opening tool.
  3. Toshiba Satellite L455-S5975 WiFi Card Replacement: 3 단계, 이미지 1/3 Toshiba Satellite L455-S5975 WiFi Card Replacement: 3 단계, 이미지 2/3 Toshiba Satellite L455-S5975 WiFi Card Replacement: 3 단계, 이미지 3/3
    • Locate the Wifi Card on the right-hand side of compartment you just revealed
    • Remove the black and white wire by carefully pulling them off with the plastic lever (you will hear a light snapping sound).
  4. Toshiba Satellite L455-S5975 WiFi Card Replacement: 4 단계, 이미지 1/1
    • Unscrew the two 6 mm screws (indicated in red) located at the bottom of the WiFi card and store them in a safe place.
  5. Toshiba Satellite L455-S5975 WiFi Card Replacement: 5 단계, 이미지 1/2 Toshiba Satellite L455-S5975 WiFi Card Replacement: 5 단계, 이미지 2/2
    • Gently remove the wifi card from the laptop.
결론
Note: When installing new WiFi card be sure to connect the black wire to the right where there is a small letter “B” imprinted and place white on the opposite side.
다른 2명이 해당 안내서를 완성하였습니다.
Dylan Baker
회원 가입일: 03/11/14
188 평판
안내서 1개 작성함
UMD team 2 UMD team 2 회원
Community
4 회원들
안내서 1개 작성하였습니다
댓글 한 개
are you aware of any compatible upgrades for a faster speed, like a dual band 5ghz card? from what im gathering its probably not worth the trial and error, because the antenna is designed probably for just 2.4ghz, so i'm thinking a usb dongle is the best option but wondering what your thoughts are? great guide btw
Tyler Bombara - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 11
전체 시간: 2,240
