주요 콘텐츠로 건너뛰기
Toshiba Satellite L455D-S5976 CPU Replacement
필요한 것
  1. Toshiba Satellite L455D-S5976 CPU Replacement, Battery: 1 단계, 이미지 1/1
    • Unlock the right tab by sliding it to the right with your finger.
  2. Toshiba Satellite L455D-S5976 CPU Replacement: 2 단계, 이미지 1/1
    • Hold the left tab to the left using your left hand.
  3. Toshiba Satellite L455D-S5976 CPU Replacement: 3 단계, 이미지 1/1
    • Remove the battery by placing your finger in the middle groove and lifting up.
  4. Toshiba Satellite L455D-S5976 CPU Replacement, Optical Drive: 4 단계, 이미지 1/1
    • Remove the 13 Phillips #1 10mm screws from the backside of your computer using a Phillips #1 screwdriver.
  5. Toshiba Satellite L455D-S5976 CPU Replacement: 5 단계, 이미지 1/1
    • Remove the two Phillips #1 6mm screws from the backside of your computer using a Phillips #1 screwdriver.
  6. Toshiba Satellite L455D-S5976 CPU Replacement: 6 단계, 이미지 1/1
    • Remove the three 3mm screws from beneath the battery with a Phillips #1 screwdriver.
  7. Toshiba Satellite L455D-S5976 CPU Replacement: 7 단계, 이미지 1/1
    • Lift up the corner panel and remove it with your hand.
  8. Toshiba Satellite L455D-S5976 CPU Replacement: 8 단계, 이미지 1/1
    • Unscrew the four Phillips #1 3mm using a Phillips #1 screwdriver.
    • Unscrew the four 10mm screws around hard drive using a Phillips #1 screwdriver.
  9. Toshiba Satellite L455D-S5976 CPU Replacement: 9 단계, 이미지 1/2 Toshiba Satellite L455D-S5976 CPU Replacement: 9 단계, 이미지 2/2
    • To remove the hard drive case, first pull the black tab to the right.
    • Then pull the black tab up to remove the case.
  10. Toshiba Satellite L455D-S5976 CPU Replacement: 10 단계, 이미지 1/3 Toshiba Satellite L455D-S5976 CPU Replacement: 10 단계, 이미지 2/3 Toshiba Satellite L455D-S5976 CPU Replacement: 10 단계, 이미지 3/3
    • Remove the plastic strip above the "F" keys using the spudger by placing the small end of the spudger under the strip and lifting up.
  11. Toshiba Satellite L455D-S5976 CPU Replacement: 11 단계, 이미지 1/1
    • Remove the two Phillips #1 3mm screws underneath the plastic strip using a Phillips #1 screwdriver.
  12. Toshiba Satellite L455D-S5976 CPU Replacement: 12 단계, 이미지 1/1
    • Lift the keyboard up and remove it with your hands.
  13. Toshiba Satellite L455D-S5976 CPU Replacement: 13 단계, 이미지 1/1
    • Remove the five Phillips #1 10mm screws underneath the keyboard using a Phillips #1 screwdriver.
  14. Toshiba Satellite L455D-S5976 CPU Replacement: 14 단계, 이미지 1/3 Toshiba Satellite L455D-S5976 CPU Replacement: 14 단계, 이미지 2/3 Toshiba Satellite L455D-S5976 CPU Replacement: 14 단계, 이미지 3/3
    • Lift up the plastic panel and carefully disconnect the red and white ports.
    • Remove the panel
  15. Toshiba Satellite L455D-S5976 CPU Replacement: 15 단계, 이미지 1/1
    • Turn the laptop over so the bottom is facing up
    • Then remove the 3mm screw with a #1 screwdriver, located underneath the panel containing the wifi card and RAM
  16. Toshiba Satellite L455D-S5976 CPU Replacement: 16 단계, 이미지 1/1
    • Turn the laptop back over so the motherboard is facing up
    • Now slide the optical drive out of the computer by gently pulling it to the right
  17. Toshiba Satellite L455D-S5976 CPU Replacement, CPU: 17 단계, 이미지 1/1
    • Remove the two Phillips #1 3mm screws from the fan using a Phillips #1 screwdriver.
  18. Toshiba Satellite L455D-S5976 CPU Replacement: 18 단계, 이미지 1/1
    • Remove the two cables from the fan.
  19. Toshiba Satellite L455D-S5976 CPU Replacement: 19 단계, 이미지 1/2 Toshiba Satellite L455D-S5976 CPU Replacement: 19 단계, 이미지 2/2
    • LIft up on the fan and remove it from the computer.
  20. Toshiba Satellite L455D-S5976 CPU Replacement: 20 단계, 이미지 1/1
    • Remove the six 6mm screws from the motherboard with a #1 phillips screwdriver.
  21. Toshiba Satellite L455D-S5976 CPU Replacement: 21 단계, 이미지 1/1
    • Remove the lone 10mm screw from the motherboard with a phillips #1 screwdriver.
  22. Toshiba Satellite L455D-S5976 CPU Replacement: 22 단계, 이미지 1/2 Toshiba Satellite L455D-S5976 CPU Replacement: 22 단계, 이미지 2/2
    • Remove the motherboard with your hands by carefully lifting up and pulling out.
  23. Toshiba Satellite L455D-S5976 CPU Replacement: 23 단계, 이미지 1/2 Toshiba Satellite L455D-S5976 CPU Replacement: 23 단계, 이미지 2/2
    • Remove the four Phillips #1 6mm single coil pickup screws from the cooling unit and remove the cooling unit.
  24. Toshiba Satellite L455D-S5976 CPU Replacement: 24 단계, 이미지 1/2 Toshiba Satellite L455D-S5976 CPU Replacement: 24 단계, 이미지 2/2
    • Using a flathead screwdriver, undo the lock on the CPU with a half turn in the counterclockwise direction.
    • Remove the CPU by lifting up on the chip.
결론
다른 11명이 해당 안내서를 완성하였습니다.
NateJohnson
회원 가입일: 01/26/14
1,047 평판
안내서 5개 작성하였습니다
Cal Poly, Team 9-26, Maness Winter 2014 Cal Poly, Team 9-26, Maness Winter 2014 회원
CPSU-MANESS-W14S9G26
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
Just be vary careful with unplugging any connectors. one false step and you could wind up with some more problems.
harh027213 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 3,826
