소개
The wifi card enables the computer to be compatible with wifi. If the card is malfunctioning, the computer will not receive a signal from any wifi sources. This guide shows how to remove the wifi card so it can be replaced.
필요한 것
Unscrew the Phillips #1 4mm screw from the middle panel using a Phillips #1 screwdriver.
거의 끝나갑니다!
결론
다른 4명이 해당 안내서를 완성하였습니다.
