주요 콘텐츠로 건너뛰기
Toshiba Satellite L505 Laptop Keyboard Replacement
필요한 것
  1. Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 1개 Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 2개 Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: 1 단계, 이미지 3개 중 3개
    • Open the laptop and locate the plastic strip just above the keyboard.
    • With care, slide the prying tool into an end and lift it up until you hear an audible click, meaning it has separated.
    • Slowly slide a finger or the prying tool under and follow the strip to the opposite end, completely detaching the strip.
  2. Toshiba Satellite L505 Laptop Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Toshiba Satellite L505 Laptop Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the four screws using the Phillips #1 screwdriver.
  3. Toshiba Satellite L505 Laptop Keyboard Replacement: 3 단계, 이미지 2개 중 1개 Toshiba Satellite L505 Laptop Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    • Gently push the clip back as you lift the top of the keyboard towards you.
    • There is a cable connecting the keyboard to the motherboard so do not lift the keyboard all the way out yet.
  4. Toshiba Satellite L505 Laptop Keyboard Replacement: 4 단계, 이미지 3개 중 1개 Toshiba Satellite L505 Laptop Keyboard Replacement: 4 단계, 이미지 3개 중 2개 Toshiba Satellite L505 Laptop Keyboard Replacement: 4 단계, 이미지 3개 중 3개
    • Gently disconnect the connector strip by pushing the white clips forward.
    • Carefully pull the strip out of its port.
    • Remove the keyboard from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Matias
회원 가입일: 09/26/18
1,028 평판
안내서 9개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 1,286
