주요 콘텐츠로 건너뛰기
Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement
필요한 것
  1. Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement, Keyboard: 1 단계, 이미지 3개 중 1개 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement, Keyboard: 1 단계, 이미지 3개 중 2개 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement, Keyboard: 1 단계, 이미지 3개 중 3개
    • Open the laptop and locate the plastic strip just above the keyboard.
    • With care, slide the prying tool into an end and lift it up until you hear an audible click, meaning it has separated.
    • Slowly slide a finger or the prying tool under and follow the strip to the opposite end, completely detaching the strip.
  2. Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: 2 단계, 이미지 2개 중 1개 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the four screws using the Phillips #1 screwdriver.
  3. Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: 3 단계, 이미지 2개 중 1개 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Gently push the clip back as you lift the top of the keyboard towards you.
    • There is a cable connecting the keyboard to the motherboard so do not lift the keyboard all the way out yet.
  4. Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: 4 단계, 이미지 3개 중 1개 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: 4 단계, 이미지 3개 중 2개 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: 4 단계, 이미지 3개 중 3개
    • Gently disconnect the connector strip by pushing the white clips forward.
    • Carefully pull the strip out of its port.
    • Remove the keyboard from the device.
  5. Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement, Optical Drive: 5 단계, 이미지 2개 중 1개 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement, Optical Drive: 5 단계, 이미지 2개 중 2개
    • Turn the laptop upside down.
    • Remove the screw labeled F4 using the Phillips #1 screwdriver.
    • There are 2 screws labeled F4, the correct screw is the one closer to the hard drive.
  6. Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: 6 단계, 이미지 2개 중 1개 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: 6 단계, 이미지 2개 중 2개
    • Gently slide the optical drive out of the device.
  7. Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement, Battery: 7 단계, 이미지 1개 중 1개
    • Turn your laptop upside down, at the bottom of the laptop, slide the right sliding lock to the unlocked position.
    • Slide the left sliding lock to the left and hold it. Using your fingers lift the battery out.
  8. Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement, Palm Rest Assembly: 8 단계, 이미지 3개 중 1개 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement, Palm Rest Assembly: 8 단계, 이미지 3개 중 2개 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement, Palm Rest Assembly: 8 단계, 이미지 3개 중 3개
    • Unscrew all of the screws marked on the underside of the laptop.
    • Remove the screw marked in the second photo by lifting up the lid and unscrewing using a Phillips #1 screwdriver.
    • Remove the three flat screws in the port where the Optical drive is housed in.
  9. Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: 9 단계, 이미지 2개 중 1개 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the keyboard and once that has been done, remove the screw marked "16."
    • Disconnect all of the cables with a blue circle.
  10. Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: 10 단계, 이미지 3개 중 1개 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: 10 단계, 이미지 3개 중 2개 Toshiba Satellite L505 Laptop Palm Rest Assembly Replacement: 10 단계, 이미지 3개 중 3개
    • Using the opening tool, carefully go around the edge and loosen the palm-rest assembly, until you can comfortably and easily lift it off.
결론
작성자
3다른 기여자 명과 함께
Matias
회원 가입일: 09/26/18
1,028 평판
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 11
전체 시간: 554
