주요 콘텐츠로 건너뛰기
Toshiba Satellite L505D-GS6000 Battery Replacement
필요한 것
  1. Toshiba Satellite L505D-GS6000 Battery Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite L505D-GS6000 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Shut down the computer and disconnect all cables.
    • Flip the computer over so that the bottom is facing up.
    • Slide right switch above the battery so that it is in the rightwards position.
  2. Toshiba Satellite L505D-GS6000 Battery Replacement: 2 단계, 이미지 1/1
    • Push and hold the left-most switch in the leftward position.
    • While holding the left switch in position, lift up on the battery from the groove in the casing and remove.
결론
Adam Dellicker
회원 가입일: 03/19/18
539 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S4-G2, Covino Spring 2018 UMass Dartmouth, Team S4-G2, Covino Spring 2018 회원
UMASSD-COVINO-S18S4G2
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 9
전체 시간: 339
