주요 콘텐츠로 건너뛰기
Toshiba Satellite L505D-GS6000 Disk Drive Replacement
필요한 것
  1. Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Shut down the computer and disconnect all cables.
    • Flip the computer over so that the bottom is facing up.
    • Slide right switch above the battery so that it is in the rightwards position.
  2. Toshiba Satellite L505D-GS6000 Disk Drive Replacement: 2 단계, 이미지 1/1
    • Push and hold the left-most switch in the leftward position.
    • While holding the left switch in position, lift up on the battery from the groove in the casing and remove.
  3. Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Disk Drive: 3 단계, 이미지 1/1
    • Remove the M2 5x6 mm screw pointed out in the picture using the Phillips #0 screwdriver.
    • You do not need to remove anything else in order to take out the disk drive.
  4. Toshiba Satellite L505D-GS6000 Disk Drive Replacement: 4 단계, 이미지 1/1
    • Gently slide the disk drive out to the right until it is removed from the computer.
    • If the disk drive doesn’t easily slide out then there is possible damage on the inside of the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Adam Dellicker
회원 가입일: 03/19/18
539 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S4-G2, Covino Spring 2018 UMass Dartmouth, Team S4-G2, Covino Spring 2018 회원
UMASSD-COVINO-S18S4G2
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 8
전체 시간: 355
