주요 콘텐츠로 건너뛰기
Toshiba Satellite L505D-GS6000 Key Replacement
필요한 것
  1. Toshiba Satellite L505D-GS6000 Key Replacement, Key: 1 단계, 이미지 1/3 Toshiba Satellite L505D-GS6000 Key Replacement, Key: 1 단계, 이미지 2/3 Toshiba Satellite L505D-GS6000 Key Replacement, Key: 1 단계, 이미지 3/3
    • Open laptop in the front facing position.
    • Use a plastic opening tool to remove the desired key from the keyboard.
    • When lifting up on the key, do so carefully as to not break the key or its housing underneath.
  2. Toshiba Satellite L505D-GS6000 Key Replacement: 2 단계, 이미지 1/1
    • Use a finger to push a new key into place.
결론
If the key does not feel like it feels to be in the correct position, retry the process following the steps in order again.
Adam Dellicker
회원 가입일: 03/19/18
539 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S4-G2, Covino Spring 2018 UMass Dartmouth, Team S4-G2, Covino Spring 2018 회원
UMASSD-COVINO-S18S4G2
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 4
30일 전: 7
전체 시간: 433
