주요 콘텐츠로 건너뛰기
Toshiba Satellite L505D-GS6000 RAM Replacement
필요한 것
  1. Toshiba Satellite L505D-GS6000 RAM Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite L505D-GS6000 RAM Replacement, Battery: 1 단계, 이미지 2/2
    • Shut down the computer and disconnect all cables.
    • Flip the computer over so that the bottom is facing up.
    • Slide right switch above the battery so that it is in the rightwards position.
  2. Toshiba Satellite L505D-GS6000 RAM Replacement: 2 단계, 이미지 1/1
    • Push and hold the left-most switch in the leftward position.
    • While holding the left switch in position, lift up on the battery from the groove in the casing and remove.
  3. Toshiba Satellite L505D-GS6000 RAM Replacement, RAM: 3 단계, 이미지 1/2 Toshiba Satellite L505D-GS6000 RAM Replacement, RAM: 3 단계, 이미지 2/2
    • Place the laptop upside down so the bottom is facing up and the side that opens is facing you.
    • In the middle of the laptop there is a panel held down by one 6 mm screw, remove that screw using a Phillips #0 screwdriver.
    • Place the screw down in a place that you will not lose it.
    • Remove the RAM cover.
  4. Toshiba Satellite L505D-GS6000 RAM Replacement: 4 단계, 이미지 1/2 Toshiba Satellite L505D-GS6000 RAM Replacement: 4 단계, 이미지 2/2
    • The unlock the RAM push out on the metal pieces touching the RAM on the bottom and top side until it clicks
    • Once you do that gently slide the ram out and place it to the side.
    • Be gentle as to not damage any of the pieces within the laptop, excessive force could break the RAM slots and require more repairs.
  5. Toshiba Satellite L505D-GS6000 RAM Replacement: 5 단계, 이미지 1/2 Toshiba Satellite L505D-GS6000 RAM Replacement: 5 단계, 이미지 2/2
    • You’ll need to do the same as the top for the bottom set of RAM, so gently push outward on the metal pieces above and below the RAM.
    • Again be gentle when following these steps as you could could cause more damage than you’re able to fix.
    • Gently slide the RAM out from the slot.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Adam Dellicker
회원 가입일: 03/19/18
539 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S4-G2, Covino Spring 2018 UMass Dartmouth, Team S4-G2, Covino Spring 2018 회원
UMASSD-COVINO-S18S4G2
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 6
전체 시간: 391
