소개
Use this guide to replace your RAM.
If you are experiencing memory issues or your computer struggles to run some programs, then you should use this.
The process is simple and requires only removing one screw.
필요한 것
Flip the computer over so that the bottom is facing up.
Slide right switch above the battery so that it is in the rightwards position.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
