주요 콘텐츠로 건너뛰기
Toshiba Satellite L55-A CMOS Battery Replacement
필요한 것
  1. Toshiba Satellite L55-A CMOS Battery Replacement, Remove the RAM cover: 1 단계, 이미지 1/1
    • Before you begin, be sure to power down your laptop.
    • Flip the laptop over so that the back cover is facing up.
    • Unscrew the captive Phillips screw securing the RAM cover.
  2. Toshiba Satellite L55-A CMOS Battery Replacement: 2 단계, 이미지 1/2 Toshiba Satellite L55-A CMOS Battery Replacement: 2 단계, 이미지 2/2
    • Lift up the edge of the RAM cover and remove it.
  3. Toshiba Satellite L55-A CMOS Battery Replacement, Disconnect the ethernet connector cable: 3 단계, 이미지 1/3 Toshiba Satellite L55-A CMOS Battery Replacement, Disconnect the ethernet connector cable: 3 단계, 이미지 2/3 Toshiba Satellite L55-A CMOS Battery Replacement, Disconnect the ethernet connector cable: 3 단계, 이미지 3/3
    • Use an opening tool to pry up the ethernet connector cable from its socket near the RAM module.
    • Disconnect the cable.
    • During reassembly, make sure you re-insert this connector right-side-up. The connector is keyed to plug in only one orientation, so if it doesn't slide into place easily, turn it around and try the other way.
  4. Toshiba Satellite L55-A CMOS Battery Replacement, Remove the back cover: 4 단계, 이미지 1/1
    • Remove the thirteen 6.8 mm long Phillips screws securing the back cover.
  5. Toshiba Satellite L55-A CMOS Battery Replacement: 5 단계, 이미지 1/3 Toshiba Satellite L55-A CMOS Battery Replacement: 5 단계, 이미지 2/3 Toshiba Satellite L55-A CMOS Battery Replacement: 5 단계, 이미지 3/3
    • Insert the point of an opening pick in the seam between the SuperMultiDrive and the rest of the back cover.
    • Push the SuperMultiDrive's lip away from the back cover to disconnect the drive.
    • Slide the drive out of the bay and remove it from the laptop.
  6. Toshiba Satellite L55-A CMOS Battery Replacement: 6 단계, 이미지 1/2 Toshiba Satellite L55-A CMOS Battery Replacement: 6 단계, 이미지 2/2
    • The back cover is still held in place by plastic clips.
    • Insert the point of an opening pick into the back cover seam near the ethernet port.
    • Twist the pick to release the plastic clips along the edge.
  7. Toshiba Satellite L55-A CMOS Battery Replacement: 7 단계, 이미지 1/3 Toshiba Satellite L55-A CMOS Battery Replacement: 7 단계, 이미지 2/3 Toshiba Satellite L55-A CMOS Battery Replacement: 7 단계, 이미지 3/3
    • Grasp the loosened back case edge with your hand and lift it slowly away from the laptop. The remaining clips should release with ease.
    • If you meet significant resistance, stop and check for forgotten screws.
    • Remove the back cover.
    • To reinstall the back cover, align the cover and press along the edges to snap the clips back in place.
  8. Toshiba Satellite L55-A CMOS Battery Replacement, Remove the coin cell: 8 단계, 이미지 1/3 Toshiba Satellite L55-A CMOS Battery Replacement, Remove the coin cell: 8 단계, 이미지 2/3 Toshiba Satellite L55-A CMOS Battery Replacement, Remove the coin cell: 8 단계, 이미지 3/3
    • Use your fingernail or an opening pick to push the gold metal clip off of the top of the coin cell.
    • Pry the coin cell out of its holder and remove it.
    • To install a replacement battery, align the battery and press it firmly into the holder until the battery snaps into position.
결론
Arthur Shi
회원 가입일: 01/03/18
249,876 평판
안내서 503개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,732개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 40
전체 시간: 2,380
